Using an alternate language in the ArcGIS Online Water Distribution Utility Network Foundation data template?
1532
11-19-2021 03:56 AM
Labels (2)
JuhaHaanpera
We have deployed ArcGIS Online based Water Distribution Utility Network Foundation to a local water distribution company. Is it possible to use Finnish language aliases in the data model of the Water Distribution solution?
JoelSmith3
Esri Alum
It is possible to use the Modification Tables to add Finnish Aliases to the components of the Water Distribution Network Foundation solution. Use the steps here: to add a D_Rename table.
After the field has been added, translate the values in the "Current Name" field into the Finnish field for each row in the table.
When you are ready to apply your asset package you will see the option to select Finnish in the "Rename using".
I hope this helps!
JuhaHaanpera
Clarification and correction to my previous post that we are providing customers with an ArcGIS Online based Water Distribution Data Management Solution, and not an ArcGIS Enterprise based Water UN solution. We need localization in the Finnish language for the AGOL-based Water Solution data model.
Is there any instruction in AGOL solution that can be used to translate the data model with aliases? This guide is for the Enterprise based UN solution only, isn't it?
Thanks.
