Hi, we are in the process of final migration of ESRI UNModel on Water and we are not able to move forward on below step, could anyone help us to understand how to fix the error or how to move forward.Please find below attached issue.
Publish water utility network services - Repair the utility network maps
This issue could not be resolved even if we source enterprise database, please let us know.
Also we are not able to understand this step as well.
Where we can see these two maps. We could only see only one. Please suggest.
Most of the process in steps are cumbersome process, it should be as simple as simple to apply. Please suggest any one of you if done.,
Those red exclamation points are whether the layer can be edited or not. Because you are branch versioned, it is expected behavior that you cannot edit (you must publish and edit via services).
You can swap to this view mode:
We are not able to proceed this step" Publish the feature service" after ignoring below steps and below is the error.
Update the spatial reference of the maps
It is showing errors as below
You need to register your data with server. (If you right-click the error, it will present you with some choices.)
