When I try to deploy Water Distribution Network Editor v3.2 I get a fail, It says that Layer's data source is inaccessible, but I don't know where find the disruption.
I already deploy Water Distribution Network Viewer v3.2 and It works perfectly with the same published Utility Network demo data.
Hi Norah,
It appears that you have a previous version of the Water Distribution Utility Network Foundation deployed (possibly version 3.0). Notice the blue exclamation next, this indicates a newer version is available.
The rectifier cable was added at version 3.2
I would recommend deploying the new Water Distribution Utility Network Foundation, publishing a new service, and then deploying the Editor and Viewer.
Joel
Hi Norah,
Joel
Hi Joel!
Thank you very much for your answer. I did what you suggest, but when I try to deploy the Editor Pro ask for Portal credential for arcgisutilitysolutions.esri.com (I attach an image about this issue).
Do you know what I should do?
Norah,
Sorry for the inconvenience, we had to make an update on our end but you should be good to deploy the Water Distribution Network Editor now.
Gelisa
