We added five new fields to the Service Line hosted feature layer item (see attachment) and want to modify the Lead Service Line Editor web app to allow batch editing of these new fields. The Batch Editor widget doesn't recognize the new fields. All fields are editable. Has anyone tried adding a new field to the Batch Editor widget? I'm using Web App Builder.
Hi Chris,
That is a known bug and has a targeted fix for the June ArcGIS Online release. In the meantime there are a couple of workarounds:
Method 1
Method 2
Hi Chris,
Method 1
Method 2
ah...thanks. I was doing everything except re-adding the layer to the web map.
