How to reconfigure Water Isolation Trace Web AppBuilder Widget
3719
06-16-2016 05:15 AM
Gerald_ZBray
All,
I am wanting to reconfigure the Water Utility Isolation Trace Widget to work on my Electric Distribution utility network.  Here is a link to the example Utility Isolation Trace | ArcGIS for Water .  I have downloaded the example but the geoprocessing model was beyond my current level of knowledge.  I am hoping to be able to configure something that would allow my users to select a starting point, possibly add barriers and then request a trace.  The results would then be offered up for the user to review, print or possibly export.
I realize that sounds like a lot but it is a normal workflow for us.  I have seen all the different parts as examples, just not all put together.
Can anyone offer me assistance?
Tags (1)
MikeMillerGIS
Esri Frequent Contributor
Zach,
  Are you looking for a find connected trace?  Do you want to stop of protective devices?
Start with a basic model
Add a feature set and set the symbology to a point layer - This will let you click a point
Pass that feature set into the Trace GP tool
In that Trace Tool, set you disable layer as the device you want to stop the trace, like a switch
Set the trace type to Find Connected
The results will be the Geometric network with selected features, so you can use the Make Feature layer to get the results and return it to the widget.
ZlatinaGounev1
Hi Zach,
Were you able to build an electric Distribution Trace Widget? I am looking for exactly the tool you have described above.
Thank you
Zuzi
