Attribute Assistant - Config file, Load Last Array enhancement from Jan 2018
1973
03-25-2021 10:57 AM
Labels (2)
JimGrimes
Where in the AA config file can I find this enhancement from Jan 2018 in the latest ver 2019.2.14?
Below is the config files that comes with the most recent download of the AA.
| Version 3.1.17
| Copyright 2018 ESRI
| Licensed under the Apache License, Version 2.0 (the "License");
| you may not use this file except in compliance with the License.
| You may obtain a copy of the License at
| http://www.apache.org/licenses/LICENSE-2.0
| Unless required by applicable law or agreed to in writing, software
| distributed under the License is distributed on an "AS IS" BASIS,
| WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied.
| See the License for the specific language governing permissions and
| limitations under the License.
<configuration>
<Name>Attribute Assistant Release</Name>
<appSettings>
<!--Options for the Attribute Assistant-->
<!--Option to turn on the AA on startup-->
<add key="AttributeAssistant_EnabledOnStartUp" value="True" />
<!--Option to turn on the AA on when editing is started-->
<add key="AttributeAssistant_EnabledOnStartEditing" value="False" />
<!--The name of the table that defines the functions for the Attribute Assistant-->
<add key="AttributeAssistant_TableName" value="DynamicValue" />
<!--The table used for Unique ID Generation-->
<add key="AttributeAssistant_GenerateId_TableName" value="GenerateId" />
<!--Activate the debug mode which writes a log file-->
<add key="AttributeAssistant_Debug" value="True" />
<!--Path to store the log file, do not include the file name. The default location is %USERPROFILE%\ArcGISSolutions -->
<add key="AttributeAssistant_Debug_Path" value="" />
<!--Option to clear the last values between toggling it on and off-->
<add key="AttributeAssistant_ClearLastValue" value="False" />
<!--Option to clear the last value array when you switch a version-->
<add key="AttributeAssistant_ClearLastValueStopEdit" value="False" />
<!--The geocoder used by the AA for the Get_Address rule-->
<add key="Geocoder" value="http://geocode.arcgis.com/arcgis/rest/services/World/GeocodeServer/"/>
<!--Field names in the Generate ID Table-->
<add key="SequenceName" value="SEQNAME"/>
<add key="SequenceCounter" value="SEQCOUNTER"/>
<add key="SequenceInterval" value="SEQINTERV"/>
<!--Option to delete features without AA processing related records. If True, delete operations will be much quicker when AA is enabled.-->
<add key="BypassEditOperationCheck" value="True"/>
<!--Option to call on create instead of On Change Geometry when a line or polygon is split using the Split Tool.-->
<add key="OnCreateWhenSplit" value="True"/>
<!--Option to call a stored procedure for generating the ID seq.-->
<add key="GenerateIDStoreProceName" value=""/>
<!--Option to expose commented on AA prompts.-->
<add key="ShowCommentsOnPrompt" value="False"/>
<!--Option to suppress stored event on all cases, only disable if experiancing issue with the parcel fabric. May case issues with other rules-->
<add key="SetStoreEventsRequired" value="True"/>
</appSettings>
</configuration>
JimGrimes
Ok. So i've learned that the enhancement was an added as an option to the Value Info for Last Value method in the Dynamic Value table.  Just not sure how to configure that Value Info field for our circumstances.
