Will 10.2.x ArcHydro tools install on 10.3?
21779
12
12-15-2014 03:49 PM
curtvprice
I'm assuming the answer is no, but I thought I'd check, as there aren't major platform changes as far as I know.
Does the team have plans to create a 10.3 version in the next six months, or should plan to stick with 10.2.2 for a while?
NICOLAPEDDIS
Every version of arcgis have the proper archydro installer
arcgis 10.2 and 10.2.x-->yellow.esri.com - /archydro/archydro/Setup/10.2.x/
arcgis v10.3 and 10.3.x--> yellow.esri.com - /archydro/archydro/Setup/10.3/
you need always to choose the last build available, and apply every patch to your arcgis, to avoid problems.
Yessica_NataliaRamirez
Thank you so much! ArcHydro tools is already working on ArcGIS 10.3.1
ChristineDartiguenave
It will not. You need to install the 10.3 version for ArcGIS 10.3/10.3.1. You can download the latest build from the following location
http://downloads.esri.com/archydro/archydro/setup/10.3
Christine
Christine Dartiguenave
Esri Water Resources Team
