Smoothing the DEM
7797
19
06-22-2023 02:33 PM
Labels (2)
HusamAbuOqer
Hello everyone,
I am working on the Archydro toolset and I am facing an issue with the perona malik smoothing method, the mean and median areworking normally but the perona malik is not working and showing the error below.
(I am using the DEM I generated from the LAS file data)
Tags (1)
GinaO_Neil
Yes, that's a very large dataset. Over several tests I found that wetlands were better predicted by topographic indices calcualted from 3m DEM than from a 1m (or higher res) DEM. I recommend resampling your data up to 3m and working in one HUC12 at a time - i.e., calculated predictor variables for a single HUC12 extent. That sounds like amazing ground truth data! You should have the opportunity in that case to train wetlands in one HIC12 and use the trained model to predict wetlands in a separate HUC 12
HusamAbuOqer
@GinaO_Neil  Thank you so much for your reply!
I will check on this now.
GinaO_Neil
No problem! Let me know if you continue to run into issues. I am happy to set up a screenshare as well. Good luck!
HusamAbuOqer
@GinaO_Neil  appreciate your support
Now this issue has been solved but I am facing another issue again when I run the random trees model as I only get a raster with one or zero value.
I have tried to use different constraints area or not add the constraint and it's still the same!
Do you know what could cause this?
GinaO_Neil
Can you include a screenshot of your training data?
HusamAbuOqer
Sure
So this image includes the constraint I have created within the study area.
And the other screenshot indicates the train.tff after running the test split tool.
GinaO_Neil
It looks like your constraint is capturing an area with no wetlands. I may not be fully understanding your workflow. But I recommend the following:
  • choose one HUC12 in your study area and clip a 3m DEM to that area
  • derive predictor variables for that clipped DEM
  • use Preprocessing Groundtruth Data to prepare your known wetlands, using the HUC12 boundaries as the extents
  • create a polygon feature class within your HUC12 to use as your constraint (create a polygon that encompasses a mix of both wetlands and nonwetlands)
  • run Train Test Split with the constraint
  • continue with WIM workflow
HusamAbuOqer
I am working on a study area in Canada so no HUC12 is available.
I think the issue could be caused because we are using different data than you have used.
Can we set up a meeting so I can discuss the data I am using with you?
Thank you!
GinaO_Neil
Sure thing. Please email me and we'll get something scheduled! goneil@ersi.com
HusamAbuOqer
Thank you Gina!
I tried to send you an email but I got a failure message.
Did you get any emails?
