RiverLength Tool not found with HEC-GeoHMS for ArcGIS 10.1
6807
05-01-2013 01:18 AM
PatrickNdolo_Goy
Someone can help me please with this Hec-GeoHMS 10.1 trouble.
When I try to launch the RiverLength tool or any other tool of the characteristics menu, I get this message: ???RiverLength tool not found. Please add GeoHMS Tools to the toolbox and try again!???. I don't now what it's happened.
GeoHMS is  installed correctly, I used it  for all the Basin Procesing in the same project watershed.
Patrick.
PatrickNdolo_Goy
I found the solution. I just added the GeoHMS toolbox installed apart in another folder to the ArcTool box. It works now.
Patrick.
TanjaMeis
I have a similar problem. When I try to select HMS Processes (--> Parameters --> Select HMS Processes) i get the following message: "Select HMS processes tool not found. Please add GeoHMS Tools to the toolbox and try again!"
Can someone help me to find a solution for this problem?
Thanks!
jingliu8
I am having same issue. can anyone help me with this? Thanks
KonstanzeFila
Hello everybody,
I have encountered the same issue, but finally found a solution.
In my case  I was using different versions of ArcMap (10.6.1), ArcHydroTools (10.3) and HEC GeoHMS (10.2).
That didn't matter for my previous modelling steps, but for the "Characteristics" -> "River Length" Tool it seems to be a problem.
So by using ArcMap (10.2) and reinstalling ArcHydroTools (10.2) and HecGeoHMS (10.2) I could solve the problem.
Greetings,
Filko
