Line artifacts in flood depth raster (Flood from Stream WSE)
1716
05-23-2018 09:08 AM
JessicaKlassen
I'm trying to create a flooding depth raster by using the "Stream WSE from point WSE Measurements" and "Flood from Stream WSE" as in (https://blogs.esri.com/esri/arcgis/2014/03/17/floodplain-delineation-using-only-arc-hydro-models).  However, my output flood depth raster has line artifacts/abrupt changes in flooding depth that to not make sense given the underlying DEM is smooth in these locations.  See the attached picture for an example, I'm using Lidar data for my DEM.
Any ideas on what would be causing these line artifacts?  Thanks!
MarkBoucher
Honored Contributor
Similar question here: https://community.esri.com/thread/110326
MarkBoucher
Honored Contributor
I recently experienced this.  I was creating a DEM from LiDAR (LAS files).
I found that I had the DEM grid size different in the settings of a couple of geoprocessing tools. I had one process using 1' DEM and another using 2'. Had very strange patterns. Once I discovered my error, made the correction, and the phantom lines when away.
EdCarter
We are having the same trouble.   Is there a way to put breaklines in or reinforce the DEM so values are interpolated from the appropriate source?  In our case it is interpolating over ridges in the DEM, sometimes just partially.
