Issue with Clipping a Shapefile to Mosaic
2751
01-17-2014 12:08 PM
LaylaBz
I am trying to clip a stream to my mosaic layer. But it???s not working.
I downloaded all my data from USGS.  I created the mosaic file out of the several img files (DEM) following this instruction:
ArcCatalog > New Geodatabase > Rightclick > New Mosaic Dataset > Rightclick > Load data > and picked all my img files as input.
Afterwards, I opened a new ArcMap file and added the mosaic layer I had created in the previous step.
The ways I tried to clip:
1) Used the Geoprocessing tab > Clip > but the Mosaic layer wouldn???t show on the ???Clip Feature??? (or ???input feature???) section.
2) ArcToolbox > Raster > Raster Processing > Clip
But with this path, the only thing that I can do is Clip the RASTER to the Shapefile.  I want to do vice versa.
Could anyone help me with this issue please?
p.s. I tried to make a polygon out of my mosaic so that I use the polygon for clipping, but I couldn???t get it to make the polygon.  Toolbox > Conversion Tools > From Raster > Raster to Polygon > input  my mosaic file but it gives me the following error:
ERROR 000864
Input raster: The input is not within the defined domain. ERROR 000863: Invalid GP data type
ChristineDartiguenave
Have you tried to construct the mosaic dataset boundary using Build Boundary and then use the Boundary Polygon to clip?
Christine Dartiguenave
Esri Water Resouces Team
