Issue Running Arc Hydro Burn Lines into DEM
555
03-19-2026 11:13 AM
Labels (2)
ALWR
Hey folks!
Recently within the past few weeks I've run into an odd case where the Burn Lines into DEM tool will not create outputs when the tool says it has ran successfully. I saw that someone else posted about a similar problem with the flatburn tool as well.
I'm wondering if this is because of Esri's latest update? Though when downloading the Arc Hydro toolset, it states the latest download is compatible with both 3.5 and 3.6 versions, so theoretically things should work just fine even with the latest update. Has anyone else run into this with the Burn Lines into DEM tool or others in the Arc Hydro toolset? If so, have you reached any fixes or solutions?
