I was wondering if you had any advice for using HEC with 10.3? I am just getting familiar with the software and wanted to incorporate it into my analysis but don't think the installer recognizes my version of 10.3.
Any advice is appreciated!
Best,Jessie
I was wondering if you had tried this for 10.3 version. I am trying to get started working with HEC, but am not able to download the software with the new version of Arc.
Any suggestions are appreciated!
I had almost the same error (I downloaded the software from http://www.hec.usace.army.mil/software/hec-georas/downloads.aspx, not beta anymore).
Starting format transformation
Transforming to internal format
Validation internal format
Transforming to GDB format
Creating Geodatabase
Unable to cast object of type 'System.__ComObject' to type 'ESRI.ArcGIS.DataSourcesGDB.FileGDBWorkspaceFactoryClass'.
at ESRI.APWR.GISXDE.ArcGISCommun.Workspaces.WSFactory.Create(WSConnectionParams conParams)
at ESRI.APWR.GISXDE.Importer.GDEImporter.Import(XmlReader source, GDEImportFormat format, WSConnectionParams connParams) Failed to import RAS data!
Mikko
Hi.
Thanks for posting the download link. I have downloaded and installed the HEC GeoRAS.
I was able to convert the sdf to xml and do the layer set up. The import RAS data keep giving error as shown below. Please what am I doing wrong?
Many thanks for your quick response. I was so impressed.
Appreciate your help.
Sara.
Sara Rastgou
The MFT site has current build -- HECGeoRAS 10.2.0.10 beta. Instructions for access are in this post -- https://community.esri.com/message/402547#402547 and then navigate to /camp/HECGeoRAS/Setup10.2_Beta directory.
An alternative http based download is here downloads /archydro/HecGeoRAS/10.2/
but this site is not kept as current (at present the HECGeoRAS builds posted are the same).
Stuart
Hi ,
I just started using ARCGIS 10.2.2 and I need a Hec-geo ras extension for that. Would you please help me.
Sara
