System.Runtime.InteropServices.COMException (0x8004005): Error HRESULT E_Fail has been returned from a call to a COM component.at ESRI.ArcGIS.Geoprocessing.GeoProcessorClass.GetEnvironmentValue(String environmentName)at HECGeoHMS9.GenerateProject.UpdateAHD(String rasterLocation, String vectorLocation, String ahProjName)
http://forums.arcgis.com/threads/8274-ArcHydro-in-ArcGIS-10?p=35289#post35289 ftp.esri.com login: RiverHydraulics password: river.1114
Stuart,This is what Revo says is left over from Apframwork. Which boxes do I check?
I am running ArcGIS Desktop 9.3.4000 on Windows XP. I recently installed Hec-GeoHMS 9.2.93.16 on my machine. It did not work correctly so aftre reading the forums I uninstalled all legacy components (including GeoRAS), cleaned the registry, and reinstalled. It took multiple tries but I finally got it to work with ApFramework9 3.1.0.42 and ArcHydro 1.4.0.124. Today I tried to reinstall Hec-GeoRAS and received the error "An incorrect version of ApFramework9 was found on the system. HEC-GeoRAS requires Apframework9 version 3.1.0.93. Please uninstall the existing ApFramework9 version and restart this installation." If I do this I suspect that Hec-GeoHMS will not work because of incompatibility with 3.1.0.93. It seems ridiculous that you would have to uninstall and reinstall every time you switched from GeoRAS to GeoHMS. Does anybody have any insight? Are versions of HEC-GeoRAS and HEC-GeoHMS that use the same ApFramework9?
http://forums.arcgis.com/threads/827...5289#post35289 ftp.esri.com login: RiverHydraulics password: river.1114
helloI am trying to install HEC-GeoRas version 4.2.93 at ArcGis 9.3 and I got the following message in the Attached Files.but wehene following the instruction, I don't find the XMl-Datexchange in Add/Remove programs? Any Ideas,
Good Day All, i encountered a problem while trying to instal Hec-Geo hms to my arcgis9.3 version, it was telling me that an older version of Apframe9 work has already been installed and cannot install untill i uninstall the older version. Please, how do i uninstall apframework9 so as to install hec-geo hms5.0 to my arcgis9.3 version. i uninstaled archyro and hec-georas, yet problem still remains. i couldnot find apframework9 on my add and remove programe
victor
