I did not have the OBJECTID field in my feature class.
MBoucher21, I have the same error that kimcarlson posted... What might be the case? Using just tutorial data for ArcHydro 2.ArcGIS 10.1, latest ArcHydro for 10.1 from the ftp
Messages Executing: DEMReconditioning "C:\Users\<msg>0;Start Time: Wed Oct 24 12:39:00 2012 Making buffer constant grid .. Making smooth constant grid .. Making sharp constant grid .. ERROR 010024: Error during conversion. Failed to execute (DEMReconditioning). Failed at Wed Oct 24 12:39:01 2012 (Elapsed Time: 1,00 seconds) Failed at Wed Oct 24 12:39:01 2012 (Elapsed Time: 1,00 seconds)
Executing: DEMReconditioning "C:\Users\<msg>0;Start Time: Wed Oct 24 14:36:19 2012 <msg>2;Failed to execute (DEMReconditioning). Failed at Wed Oct 24 14:36:19 2012 (Elapsed Time: 0,00 seconds) Failed to execute (DEMReconditioning). Failed at Wed Oct 24 14:36:19 2012 (Elapsed Time: 0,00 seconds)
Messages Executing: DEMReconditioning elev_cm.tif NHDFlowline 5 10 1000 C:\Users\<msg>0;Start Time: Wed Oct 31 17:45:10 2012 ERROR 000816: The tool is not valid. Failed to execute (DEMReconditioning). Failed at Wed Oct 31 17:45:10 2012 (Elapsed Time: 0,00 seconds) Failed at Wed Oct 31 17:45:10 2012 (Elapsed Time: 0,00 seconds)
how we can invite them to this thread?
I un- and re-installed Arc Hydro Tools and tried to run it again. When trying to "Set Target Locations", which seems simple enough, I get a "tool not valid" error. None of the tools function, various errors are returned from all of them.
I am trying to reconditioning a raster (flow accumulation) using "DEM Reconditioning". However it keeps showing the following error ( details are attached)
"System.Runtime.InteropServices.COMException (0x80004005): Error HRESULT E_FAIL has been returned from a call to a COM component.
at ESRI.ArcGIS.Geoprocessing.GeoProcessorClass.Execute(String Name, IVariantArray ipValues, ITrackCancel pTrackCancel)
My procedure is
Sink Evaluation > Flow Direction > Flow Accumulation > Fill sink > Flow Direction > Flow Accumulation > DEM Reconditioning
I have tried all the options described in this blog. Any suggestion will be highly appreciated.
Mirza,
You should do the DEM Reconditioning first. Then do fill sinks. Then do flow direction. Basically the order of operation is the order the tools appear in the menu. You don't have to use all of the tools.
The HRESULT error could be due to having the project an Arc Hydro file on a network server. Move the project to your PC and try it.
Search for the "Arc Hydro Problem Solvers" thread. I created that thread and there are lots of practical suggestions there.
Mark
Mark,
MMB
Hi Mark, I have tried to run DEM RECONDITIONING, I have tried all the solutions posted here, but I couldn't run the tool. I'm using ArcGIS 10.7, windows 10. The process starts, but I have noticed in Results that after the "Eculidean Allocations", the process "IsNull" can't be completed, as follows:
Signed in members can post, follow updates, and more. New here? Register a free account.
