DEM Reconditioning error (Arc Hydro 10.2)
10485
14
03-22-2014 10:34 AM
Houssemdagi
I am facing a problem using the arc hydro tools 10.2 fonctionnality "DEM Reconditioning" and you can check the error message in the image attached and i have no idea what i should do, so would please land me a hand.
Houssem Daagi
[ATTACH=CONFIG]32416[/ATTACH]
EfthymiosRagkousis
hello,
i tried all the solutions proposed but im stoll getting the following error:error.png
im working with windows 8 and arcmap 10.1 any new solutions?
thanks in advance
GaneshchandraMallya
Mark: I get the following error (see attached). I have made sure the target locations are set correctly as you have described. My files are on local drive, and I have also gone through the "Arc Hydro Problem Solvers" thread.
Can you kindly guide me in solving this error.
System Info:
Windows 7, 64 bit
VanPham_Thanh
Did you solve this issue, Mallya? I faced the same problem, while I am sure that the target database is correct, temp files are cleared.
ThomasColson
Is your output going to a network or a thumb drive? If so, change it to local drive. Also, I've found that creating a whole nw input/output folder and starting the whole process over sometimes clears the gremlins. Try deleting all the contents of your app data temp direcory.
MarkBoucher
Honored Contributor
Often closing ArcMap and rebooting the system clears this kind of error up also.
