ArcHydro update for ArcGIS 10.1
9994
25
07-09-2012 05:55 AM
KiPak
Is the current Arc Hydro release compatible with the recent ArcGIS 10.1 update?  Any word on a compatible version of Arc Hydro being released?
Thanks.
ChristineDartiguenave
Here is the new link:
https://mft.esri.com
Login: ADSRiverHydraulics
Password: ADSRiver.2012
Navigate to ADSRiverHydraulics/incoming/ArcHydro/Setup10.1/10.1.0.xx/ and download the msi file.
Note that the password will be reset every 6 months or so.
To access, select a FTP client:
1. Web Client
Site link: https://mft.esri.com
(Video tutorials available on the main page, prior to log in)
2. Third party SFTP client
** Download a preconfigured client
https://mft.esri.com/EFTClient/Account/mft.zip **
3. FTP address to configure a third party SFTP client of your choice:
Site address: mft.esri.com
Port: 22
Christine Dartiguenave
Esri Water Resources Team
MattNash
I was excited to see a new version of ArcHydro, hoping that it would solve the problems I've been having.  No such luck; if anything it seems even glitchier.  Every ArcHydro tool or command I try to run results in error messages and no output.  I'm wondering if any others are experiencing similar problems.
thanks
mn
AndrewZimba
From my attempts at installing, it appears the install packages are corrupt as downloaded on 12/18.
Could you please verify them?
V_StuartFoote
MVP Frequent Contributor
Andrew,
The ArcHydroTools 10.1 (v10.1.0.78 build) installer posted yesterday was incompletely uploaded, sent the Water Resources folks a note.
I've checked and today it has been replaced with a complete and working version.
Try a fresh sftp download.
Stuart
NICOLAPEDDIS
I tested the new link with WS FTP pro v12.4
type
sftp://mft.esri.com
use
When you logged you need to accept the RSA key to log inside the secure ftp site.... Click accept and you are finally inside the folder "incoming"..
You can use also the free FileZilla with the same link...
Thanks esri for the new release...
MattNash
Fixed the problem that was keeping ArcHydro tools from working.  It was a desktop clock gadget called ClockX I downloaded from CNET.  Once I uninstalled it ArcHydro tools ran smoothly.
thanks
mn
NicoleCarlozo
I would like to download ArcHydro for ArcGIS 10.0.
I have gone through the various threads and many ftp sites, passwords, and usernames were provided. What is the updated procedure for downloading this toolbox?
Thank you,
Nicole
NicoleCarlozo
I also found ArcHydro available for download here:
http://resources.arcgis.com/en/communities/hydro/01vn00000010000000.htm
Is this the most up-to-date version for Arc 10.0?
V_StuartFoote
Nicole,
No, the zip file link from the Communities Surface Water site contains the final 2.0 build, 2.0.1.133 dtd 10/10/2011; current build for ArcGIS 10.0 is 2.1.0.152 dtd 1/29/2013 available from the secure ftp site.
Also, the listed zip file version for 10.1 is also an outdated build, 10.1.0.96 dtd 1/31/2013; current build is 10.1.0.128 dtd 3/27/2013 also available from the secure ftp site.
The most current, and fully patched builds are going to be available from the secure ftp site the moderators for the Communities page seem to be a bit behind.
Stuart
NicoleCarlozo
Thanks Stuart,
I was finally able to get permission to download this on my computer, but now the username and password aren't working. Is there a new procedure for obtaining the tool?
Nicole
