ArcHydro 2.1 (ArcGIS 10.0\10.1) ArcPy Documentation
2414
02-06-2013 08:34 AM
PeterWilson
Is anyone aware of any ArcPy documentation for ArcHydro. I've seen numerous posts where individuals have started using python to some extent to run ArcHydro Tools. I was anware that ArcHydro Tools were accessible through Python or ArcPy. Is there any documention on the ArcHydroTools Python\ArcPy Module as mentioned in the following post"
Using-ArcHydro-2.0-in-a-python-script
2. We have precompiled the tools from the toolbox in a module called ArcHydroTools so that you do not have to redo the import each time which takes a long time... Then in your script you will need to add:
import ArcHydroTools
and call the tools with:
ArcHydroTools.AssignHydroID(tmpPolyFC, "OVERWRITE_YES")
Christine Dartiguenave
Esri Water Resources Team
Regards
