How can I see what sessions I attended
492
07-25-2025 07:54 AM
KimberlyGarbade
Is there a way to view a list of all the sessions you attended while at the 2025 UC in San Diego?  I had my badge scanned at the door of each session, but I don't see where I can see a list of those scans.  I used the app to find sessions, but I never logged into it, but if my badge links to an ID in a database somewhere there should be a query that can run pretty easily, right?
Leena_Abdulqader
Hi @KimberlyGarbade, You can find it on the event website. There’s an attendee portal; if you scroll down, you’ll see a “Certificate of Attendance” section. It’s a PDF that lists all the events you attended.
Hope that helps! 😊
SteveCole
Honored Contributor
You're right but ESRI's using the intrusive badge scanning simply to gauge attendance at sessions so that topics are "best fitted" for room capacity. Throughout the years, you'd have a topic with wide appeal being offered in a closet while the most obscure and focused topic of Enterprise maintenance would be housed in a room with ballroom capacity.
Leena_Abdulqader
Hope that helps! 😊
KimberlyGarbade
I did see that option, but I assumed it was just a certificate stating you had attended the conference and nothing else.  I didn't expect it to have the list of all the sessions I attended, but it sure does!  Thank you for the information!
Leena_Abdulqader
Of course! @KimberlyGarbade glad I could help
