Updated Description In All MXD's in a folder/subfolders
4567
03-08-2011 05:01 AM
by Anonymous User
Not applicable
Original User: cdeaner66
New to Python here so please be patient.
I need to update the Map Document Properties Description field in hundreds of maps in one folder and multiple sub folders.
I figured out how to add a description to the current map by using the following:
import arcpy
    mxd = arcpy.mapping.MapDocument ("CURRENT")
    mxd.desc = "Description Text Here"
How do I modify this to loop through all the MXD's in my folder/subfolders to update this field in each map?
Any insight/help would be appreciated!
Chris
JasonScheirer
Esri Alum
Let me know how this works for you:
import arcpy
import glob
import os
# Provide folder path to loop through (first level only)
folderPath = r"C:\TEMP\test"
for filename in glob.glob(os.path.join(folderPath, "*.mxd")):
    print "Editing", filename
    mxd = arcpy.mapping.MapDocument(filename)
    if not mxd.description:
        mxd.description = "Default description"
    mxd.save()
    del mxd
by Anonymous User
Not applicable
I found another script to do something similar to what I was looking to do and modified it for my needs.
It works (kind of), the only problem is I have 3 mxd's in the folder and it is only updating the last one.
Any suggestions?
Here is the code:
import arcpy, os
for filename in os.listdir(folderPath):
  fullpath = os.path.join(folderPath, filename)
if os.path.isfile(fullpath):
  basename, extension = os.path.splitext(fullpath)
if extension.lower() == ".mxd":
  mxd = arcpy.mapping.MapDocument(fullpath)
  mxd.description  = "Python Test Description"
  mxd.save()
del mxd
JasonScheirer
Esri Alum
import arcpy
import glob
import os
    mxd.save()
    del mxd
by Anonymous User
Not applicable
Thanks for the help Jason, it worked great!
Python is new to me and I appreciate the assistance.
Chris
San_Mateo_CountyGIS
The script worked for me as long as the 'description' field was empty.
Is there a way to overwrite an existing description for all MXD's in a folder?
Thanks
