Route Extent of ArcLogistics
599
10-26-2011 05:56 AM
RamonLeal_Pessoa
I want to use the ArcLogistics for fleet management in Brazil.
Therefore, I need to know if the ArcLogistics Online natively support routing on streets from Brazil.
More specifically in João Pessoa, PB, Brazil?
If it isn´t supported... Can I use my own network dataset as source for routing in ArcLogistics? If so, how this work? I will need only ArcGIS Desktop + Network Analyst? Or the ArcLogistics require one Network Analysis Service that come from ArcGIS Server?
Anyone can clarify it?
BertYagrich
Hi Ramon,
ArcLogistics Online is currently only available for use in the USA, that's the bad news.
However, ArcLogistics Desktop is available and will allow you to use your own network dataset created with ArcGIS and the Network Analyst extension but cannot use network analysis services hosted by ArcGIS Server.
Depending on the size of your fleet, other options may be available.  Feel free to email me at byagrich@esri.com and we can figure out which solution best meets your needs.
