Hotspot Analysis Symbology is Gone?
1918
07-31-2019 02:28 PM
AlexandreHughes1
Hello community,
I have run a hotspot analysis on a set of data and wanted to take that output into a custom template to quickly generate several maps, however, when I brought my hotspot point feature class into the template all of the symbology was gone -- such as the 99%-red all the way down to the 99%-blue. I'd like to bring this symbology back into play here but I have not found any helpful methods of doing this here on the forums or anywhere else for that matter.
Here is a picture of what I have currently:
Please, if you can point me in the right direction, that'd be awesome!
Robert_LeClair
Esri Esteemed Contributor
Hmmm...I wonder if by creating a template for the project/map, it "forgets" the symbology.  One thing to try is with the Map View that does have proper hot spot symbology, share it as a Layer File.  Then in your new projects, add the Layer File but repoint the source data.  Would that work?
Robert_LeClair
AlexandreHughes1
I'll try that after dinner, though, I'd like to also mention that when running the hotspot analysis it saves the file into a feature set -- point in this case -- and that was what I brought into the template. Perhaps the point feature loses its symbology?
AlexandreHughes1
That worked! Thanks so much!
