for look for ListFields
2659
12-19-2013 07:31 AM
Ryan_Galbraith
I am looking to create a for look to loop through all my ListFields and the Field name is one of the parameters in a Spatial Statistic tool.  Can anyone help please....
I am having trouble understanind what variable to declare.
by Anonymous User
Not applicable
Original User: hua17
I might be misunderstanding, but if you want to loop through all field names in a feature class, you can use arcpy.ListFields.
Something like this might work:
import arcpy
allFields=arcpy.ListFields("C://Path//To//Data.shp")
for field in allFields:
    print "Field Name: "+ field.name
    #Do stuff here
Let me know if that helps at all.
~Josh
Ryan_Galbraith
thank you, thank you, thank you!
import arcpy
arcpy.env.workspace = r"C:\StatsCanada.gdb\Saskatchewan"
featureclass = ("PopulatedCentres")
allFields=arcpy.ListFields(featureclass)
    arcpy.SpatialAutocorrelation_stats(featureclass, field.name,"GENERATE_REPORT","INVERSE_DISTANCE","EUCLIDEAN_DISTANCE","NONE","#","#")
So I got this, but it doesn't like the fields at the beginning of the fields.  Any idea how to just get the fields with numbers in them?
by Anonymous User
Not applicable
Try using "field.type", like this:
import arcpy
    if field.type in ["Double","Integer","SmallInteger"]:
If you want a bit more information on all the field types, you can find it here.
Hope it helps!
Ryan_Galbraith
Oh man, that work - perfectly!
