Find best route to Lat Long input (Destination)
1546
12-27-2010 05:28 PM
BrandonDavis
I'm trying to find a way to input a Lat Long location in Network Dataset and then find the best route to that location. The Lat long location is not a fix location i.e. Route from fire station to Forest Fire location.
Tags (1)
JaySandhu
You can use the Go To X,Y tool on the Standard Tool bar to add a graphic to map and then right-click on the Stops to Load Locations and pick the graphic as the source to "Load From".
You can read more on the X,Y tool here:
http://help.arcgis.com/en/arcgisdesktop/10.0/help/index.html#//00nm0000002p000000.htm
Alternatively if you have the X,Y's in a table, you can use the Add XY Data tool to convert that into point features and then load them as Stops.
Jay Sandhu
BrandonDavis
Jay
Thanks that did work. What If I were using a route analysis model and I had an Add location parameter could I use any xy point input. The xy points are not know meaning I could not use a predefined point layer or xy spreadsheet as my location points.
Does that make any sense?
JaySandhu
What will be your input? Can you bring the x,y in a text file? If you can, then use the
GP tool "Make XY Event Layer" found in Data Management/Layers and Table view.
Regards,
Jay Sandhu
