Hi Jose, it sounds like you're trying to import a zones shapefile that is projected in the State Plane system? If so, you'll need to use the Project Geoprocessing tool to convert the projection of your data. The actual projection used now is Web Mercator Auxiliary Sphere (WKID 102100) I believe. This tool should be available in the toolbox for ArcMap or ArcCatalog.
If you don't have a copy of ArcGIS Desktop, I'm not sure how you might do this as ArcLogistics Online won't work well with State Plane projected files.
