9.3 SP2 Arclogistic How to attach delete event of stop or folder with plugin
630
11-16-2011 09:27 AM
RizwanBashir
Hi
  I have an access database exported from arclogistic desktop app 9.3 , What I want is when I delete any record i-e order, I need an event triggered in my plugin automatically so I can remove that record from access as well.
is there any way to make this work ?
Best Regards
Rizwan Bashir
JeffWickstrom
Hello Rizwan,
You could try listening to the ArcLogistics application events.  I have attached a sample plugin that does something similar to help get you started.  I would try this sample to help you understand how the events work and how you want your logic to work.
Let us know how it goes.
Jeff
RizwanBashir
Hi
  Thankyou so very much for your prompt response with sample. it solved my problems.
Thanks again
Best Regards
Rizwan Bashir
