TGI5 - Episode 115 - Automation in Field Maps w/ Arcade and URL Parameters
1520
04-15-2025 05:21 AM
PatrickRyan
In this episode of TGI5 I show how to use Arcade to customize popups and URL parameters to create buttons that direct the user to the correct form for data collection. I compare the user experience with the standard Field Maps workflow, where the user needs to scroll to the bottom of the popup and select the table to add a record. I walk through the popup configuration and a few of the calculated expressions.
I look forward to seeing how you use Arcade and URL parameters in your field data collection!
