I am working on a project in ArcGIS Pro where I am trying to calculate total route length (polylines), but in a lot of areas I have more than one line segment. For example, if an area is 1 mile long but there are three line segments following that whole mile, I need to calculate only 1 mile, not 3 miles. The polylines are almost never overlapping so dissolving won't work. The area is quite large, sometimes the lines are 10 meters apart, sometimes only 3 meters, some run perpendicular to each other, while others run parallel. I have tried a couple of different approaches, none of which I am satisfied with. I was looking for some guidance from the community! Thank you in advance.
