basic questions: aerial span, aerial to UG transitions
1583
12-07-2011 04:48 AM
CurtMeyer
Just downloaded the Telecom Model and have read through the Telecom Network Editing Tools End User Guide, and I have a couple questions.
1. I get the modeling of underground (UG) span with the Conduit feature class and conduit geometric network, but I don't see how to model aerial span.
2. I need some guidance, also, on modeling the transition point on a fiber cable between aerial and underground. Will I need to model those points as end points of an aerial cable and an UG cable joined by what...? A FiberInterconnect feature? Can I splice, then, inside the FiberInterconnect with pass-thru splices? Or do I need to place a SpliceClosure feature at the end points and make pass-thru splices?
Thanks!
MarkReddick
You should also see a "Fiber - Overhead" sub type on the cable. Assuming you are using ArcGIS 10 you should be able to just click the "overhead" template item and that will created a cable designated as overhead.
Yes, given our fairly simple model at this time, you would need to model the transition as a splice closure location with pass through connectivity. You could also place equipment there as the transition (without a splice closure) if that is actually what you want but i suspect there would not be any in most cases. For now the splice closure with pass through is the way to go.
Hope that answers the questions.
Regards,
mark
CurtMeyer
Thanks, Mark!
We are currently at 9.3.1.
Yes, I have the aerial and UG subtypes for fiber cable. I had noticed in the Visio diagram of the model that Span was shown as a simple edge feature, and included subtypes 'Aerial' and 'Trench'. However, in the TelecomDataset I did not find a feature for aerial span.
Curt
