Avoiding Displaying Related Videos in Story Maps and Map Notes
500
09-08-2015 09:16 AM
JosephKerski
Esri Notable Contributor
I think many of you can relate to this:
When you embed a video in a story
map or Map Note, when it is done playing, by default it shows you the “related” videos –
and “related” is definitely in quotes!  Sometimes these are really
embarrassing and sit there in your story map as a set of “tiled” choices, OR
worse yet, are on the “big screen” when you are presenting to a group.
Here is a little tip to avoid that:
So, for example, compare this
embed video of mine (you can skip to just a few seconds to the end to test it):
https://www.youtube.com/embed/4IoImv0SyLM?rel=0
versus this one:  https://www.youtube.com/embed/4IoImv0SyLM
The one with the rel=0 does not
show the “related” ones at the end!
If you forget the ?rel=0 code,
then in YouTube just go to Share, Embed, and Show More, and you’ll see the
choice there that you can Uncheck to avoid the related video display.
Thanks to Owen Evans for his help with this.
DellaRobertson
Joseph,
I just wrote an article with an embedded video.  Now, I know to use rel=0.
Thank you.
Della
JosephKerski
Excellent! Thanks for replying!
Joseph
Joseph J. Kerski, Ph.D., GISP | Education Manager
Esri | 1 International Court | Broomfield CO 80021-3200 | USA
Tel 303-449-7779, ext. 1-8237 | Cell-Mobile 303-625-3925
jkerski@esri.com<mailto:jkerski@esri.com> | esri.com
Twitter: http://twitter.com/josephkerski
