AGSRequestConfiguration in 200.x
1824
5
03-12-2024 04:10 AM
zdtorok
There exists a very useful way to debug requests in 100.x, this:
let config = AGSRequestConfiguration.global()
config.debugLogFileURL = URL(fileURLWithPath: "/tmp/arcgis.md")
config.debugLogRequests = true
config.debugLogIncludeRequestHeaders = true
config.debugLogResponses = true
config.debugLogIncludeResponseHeaders = true
config.debugLogResponseTrimThreshold = 500
config.debugLogIgnoreTiledLayerRequests = true
 Is there an equivalent version in 200.x? I checked the documentation but haven't found anything similar.
NimeshJarecha
Hi @zdtorok,
Please use ConsoleNetworkLogger in 200.x for request logging. You can use following code at the start of the application.
let logger = ConsoleNetworkLogger(requestOptions: [.method, .body, .headers], responseOptions: [.data, .headers])
logger.startLogging()
Also, you can use the NetworkLogger protocol to build your own custom network logger.
Hope this helps!
Regards,
Nimesh
NimeshJarecha
Hi @zdtorok,
Hope this helps!
Regards,
Nimesh
tsroyh
Hi Nimesh,
How do you access the logs after that? Can you save them to a file? Are they visible anywhere?
Thank you
NimeshJarecha
Hi @tsroyh,
You can view the logs created by ConsoleNetworkLogger in the Xcode debug console. If you want to save the logs to a file, please create your own logger using the NetworkLogger protocol.
Regards,
 Nimesh
tsroyh
Thanks Nimesh!
Is there another step to attach the logger to the ArcGIS SDK/env/map? Just init of  ConsoleNetworkLogger and `startLogging()` doesn't seem to produce any logs.
Thank you
NimeshJarecha
Please make sure the instance of the  logger  is not getting released. If you have a SwiftUI app then you can do this,
import ArcGIS
import SwiftUI
@main
struct ExamplesApp: App {
    init() {
    var body: some SwiftUI.Scene {
