XRay for ArcCatalog shows 43 differences when "Analyze Differences" tool is run.
1363
02-19-2014 12:31 PM
JeffWard
Honored Contributor
Hey All,
Whenever I populate an empty file geodatabase with the Local Government Information Model using XRay for ArcCatalog I end up with 43 differences when I run the "Analyze Differences" tool.  I also get errors when I enable the information model on the Parcel Fabric so that I can use the parcel workflows saying that I am missing fields (specifically the FloorDesignator in the ParcelFabric_Lines and FLOORDEGNTR in TaxParcelCondo).
This doesn't seem like a very good way to get the schema loaded if it is missing fields and field properties are different.  In fact, the missing fields don't show up in the differences analysis, which seems weird.
Has anyone been able to load the schema without differences?  If so, what is the process?
Jeff Ward
Summit County, Utah
