Trouble publishing web layer from Pro to AGOL when using contingent values
1449
02-01-2019 10:23 AM
deleted-user-W9CkFLpqb-lQ
Hi there, I'm fairly new to the GIS world, so please forgive me for any ignorance.
Essentially what I'm attempting to do is create a collector app to acquire data for different types of road damages (e.g.,  throughout the County.
What I want is for certain fields to have contingent values based upon the user's selection of a road stress. For example, when a user selects "pothole" as a road stress I want a drop-down list of sizes for the pothole to appear for the user to select (i.e., 12', 18", 24", etc.). I don't want this for every field selectionjust potholes.
I've included some screenshots. Unfortunately the error message I get back when trying to publish is pretty vague and not much help.
I've tested and made sure I can publish that same feature class as a web layer when I DON'T have contingent values associated with it. But as soon as I add them, I get an error and am unable to publish.
Hopefully this makes some sense. Thank you advance for your help!
ChelseaRozek
MVP Regular Contributor
Hi, I'm having issues with publishing with contingent values as well, but I didn't get the no feature template error. I usually fix that one by just clicking on the Edit tab in pro to enter an edit session, clicking on Create, then closing/navigating away from Edit and publishing it again. You could also get fancier with creating your templates: https://pro.arcgis.com/en/pro-app/help/editing/create-a-feature-template.htm. Does that work for you then?
