Strange Parcel Lines After "Keep Changes"
1350
12-06-2013 12:30 PM
JeffWard
Honored Contributor
Greetings All,
In my quest to figure out the parcel fabric, I have been entering a few subdivisions and I am experiencing some strange behavior when constructing from parent.
I have entered a subdivision boundary, created the remainder parcel and now I am constructing the lots from the parent subdivision.  I have broken the outer subdivision lines and successfully entered the outer right-of-way lines and wanted to save my work.  It seems to me that clicking on the keep changes button would allow this, then I could open the construction in the Parcel Explorer window (which is what the popup help text for the tool says is possible).  When I opened the parcel, it looks like the order of my line points was messed up.  Now my lines go everywhere. (see attached image) I hardly think we are expected to finish the entire subdivision before saving.  Power outages, interruptions etc. are quite common.  I should be able to save my progress and come back to it later.
Did this happen because I may have deleted some courses, or modified some because of typos?  What happens when I am in the middle of entering courses and it's time to go home? What does everyone out there do?
Any response would be appreciated.
Jeff Ward
Summit County, Utah
JeffWard
Honored Contributor
I have tried to recreate this, and it seems like I can "Keep Changes" after breaking lines, but once I start cutting out the right-of-ways, the new points foul up the line point order and causes the lines to go out of order.
What is the process to save traverses?
Jeff Ward
Summit County, Utah
