Possible Issue with Fire Map Index and Fire Run Book
2535
10-17-2012 12:46 PM
AlanToms
While reviewing the Fire Run Book and the Local Gov Info Model a question came up about some fields in the FireMapIndex feature class; in particular, about the Map Sheet Number and Map Sheet Name fields.  For the feature there are several different Map Sheet Number (direction) fields so I assume the field used for the current record would follow naming convention and would be the Map Sheet Number field.  Instead, it is using the Map Sheet Name field.
Does this seem odd to anyone else?  Anyone expect a problem with the Fire Run tools if I switch the fields for my data?
Alan
JordanBrod
I never even noticed that, I haven't had any problems using wall map or working with the attribute assistant with the pre-fire planning, but I haven't tried to run any of the map book tools yet.  Hopefully you'll get an answer to your question because it does seem to be an odd choice in naming the fields.
