Park Finder / Place Finder - Distances wrong when search by Name or Activity
3616
01-13-2014 10:54 AM
LuciHawkins
I have downloaded both Park Finder 10.2 and Place Finder 10.2 from GitHub. Both produce the same error when a search is performed using "Name" or "Activity". In the "Search Results" div, they both return for example: Park Name(6,544.29 miles approx) In the "Directions" div, they both have Total distance: 5.54 miles(s) Where is it coming up with that figure next to the park name in the "Search Results" div? The distance is correct when you search by "Location".
I noticed that the example at http://tryitlive.arcgis.com/ParksFinder/ has removed the distance in question from that div when a search by Name or Activity is used. Was that due to this same bug? Anyone with any insight?
[ATTACH=CONFIG]30469[/ATTACH]
Thanks in advance!
Luci
RickeyFight
MVP Alum
Luci,
I finally figured this out!! I was having the same issue. If you open the locator.js file, then go to line 436
td.className = "selectedPark";
        if (featureSet.distance) {
            td.innerHTML = featureSet.name + " (" + dojo.number.format(featureSet.distance.toFixed(2)) + " miles)";
        } else {
            td.innerHTML = featureSet.name;
Remove the + " (" + dojo.number.format(featureSet.distance.toFixed(2)) + " miles)"
Should look like this:
            td.innerHTML = featureSet.name ;
        } else {
I hope this helps.
If I figure out to change the location to display the correct miles I will post it on this discussion.
TONIFAIRBANKS
Here's another example.
Modification example for Park Finder 2.0 locator.js file.
tdFeatureList.className = "selectedFeature";
            if (approximateValue) {
                //If the approximateValue is set in the config.js file, the approximate distance value will show in the Search Results box.  I commented out the configuration value.
                tdFeatureList.innerHTML = featureSet.name + " (" + dojo.number.format(featureSet.distance.toFixed(2)) + " miles " + approximateValue + ")";
            } else {
                //I removed the approximate value, which I assume is as a crow flies.  It is confusing when drive directions are provided.
                //tdFeatureList.innerHTML = featureSet.name + " (" + dojo.number.format(featureSet.distance.toFixed(2)) + " miles)";
                tdFeatureList.innerHTML = featureSet.name;
        } else {
