Parcels loaded as historic contain points that are not historic
2147
08-23-2012 05:31 AM
by Anonymous User
Not applicable
Original User: fellj
I am testing the loading of historic parcels (historical = 1) into the fabric but am finding something interesting. The points on the historic parcels are not historic. I would think that all components of a historic parcel would be marked historic. Is that right? Am I missing a setting or misunderstanding an intended behavior of the fabric?
by Anonymous User
Not applicable
Original User: cbuscagl
John,
When loading up the historic parcels, are the points shared by non-historic parcels?  The loader merges points since they are shared by historic and non-historic parcels, you'll get the behavior that you are seeing if that's the case.
Chris
JohnFell
Chris,
I loaded these parcels into an empty parcel fabric with a schema based off of our parcel fabric in SDE. There were no existing parcels in the fabric at the time historic parcels were loaded. Parcels and lines load in as historic yet the points do not. I was curious if perhaps I had left out a field in the fabric source data or applied the wrong setting in the load a fabric topology gp tool.
