Thanks for posting this. Came across this problem today finally.
ArcGIS 10.3 exposes the option to merge courses on build (off by default). The registry key is no longer needed.
Amir,
I can't find any additional information on this. Would you please explain where to find this option?
[Edit: I'm using 10.3.1]
Hello Nate,
From the parcel editor toolbar drop down click 'Options'.
Under the advanced tab you can change the 'Build parcels behavior' to 'Merge connected lines at points where there is no bend'
Amir
Got it - thanks!
Is there a similar option when loading parcels using arcpy.LoadTopologyToParcelFabric_fabric?
Signed in members can post, follow updates, and more. New here? Register a free account.
