I've scoured the docs and can't find any answer to this. It appears that our imported control points have moved to the location of their corresponding fabric point. Is this expected behavior? What's more strange is that when I have the 'Maintain Control Points' dialog open, I can highlight the control point in question, which flashes its location...but...it's flashing where it was originally. This, among other things, has me worried about what the control points are doing in the fabric. Has anyone else seen this or have any insights?Thanks,Mikesee attachement for illustration.[ATTACH=CONFIG]28025[/ATTACH]
Hi Mike,What is the distance between the coordinate position and the geometry's position?
If this distance is small, and you are zoomed way in, then the XY tolerance may explain what you are seeing.Also, is the parcel fabric in a geographic coordinate system, and you're projecting on the fly using the map's data frame; or is the fabric's spatial reference a projected coordinate system, and the same as the map's projected coordinate system?
Signed in members can post, follow updates, and more. New here? Register a free account.
