Maps & Apps Gallery fails to load tiles
3129
6
03-21-2013 11:01 AM
ScottTometich
One of the latest enhancements to AGOL has been to allow customers to create content that links to documents such as PDF, TIF, etc. Awesome, but adding this content to our organizational account and tagging it for use in the Maps & Apps Gallery seems to cause the Maps & Apps Gallery to fail to load tiles. I assume there is something simple in the code that needs tweaked to handle this content type, but not sure where to start. Any assistance would be appreciated!
PaulGrimes
Scott,
I had the same problem, the issue in my case was no Thumbnail (or at least I only had the default), to get it to work -  on arcgis.com edit and load an appropriate thumbnail(image) for the service/app/etc. then  save and you should be good to go.
A good way to test or debug as you go is to use firebug add-on in firefox you will see the error then.
Hope this helps!
Paulg
PaulGrimes
Scott,
Hope this helps!
Paulg
ScottTometich
Thank you, Paulg!  Adding a thumbnail to the content profile worked perfectly!  I can now store links to PDFs as document links instead of as a Web Mapping Application and my Map & App Gallery works beautifully!
Thanks again!
LindsayThomas
Thanks for reporting this issue. We will get this fixed in the coming release.
Cheers,
Lindsay
PaulGrimes
You welcome Scott
My Gallery works great also in all browsers except for firefox - in firefox the 'Most Recent' items on the carousel - the click event wont work when you click the large image .....  Is this the same for yours, I reported it in another thread by there's been no feedback.
Cheers
Paulg
ScottTometich
"My Gallery works great also in all browsers except for firefox - in firefox the 'Most Recent' items on the carousel - the click event wont work when you click the large image ..... Is this the same for yours, I reported it in another thread by there's been no feedback."
Paul-
I couldn't speak to this as I did not implement the entire site.  I stripped my site down to just the gallery tab to keep things simple.
Thanks again for the assist.
Cheers,
Scott
MikeTschudi
Esri Alum
Please see the technical article Error:  Maps and Apps Gallery 10.1.1 does not display its gallery for more information about the missing tiles.
In short, Maps and Apps Gallery 10.1.1 does not display its gallery if a gallery item does not have an icon, and the new ArcGIS Online content items are not created with any icon.
