Error when trying to add an island parcel with two curves (10.1)
1257
07-25-2012 08:20 AM
JohnFell
One of our editors is having trouble with an island parcel that has two curves. We've tried COGO'ing it in with typical parcel editor tools, using the standard editor COGO tools and pasting the lines, and creating it peice by peice yet still without any luck. The error we are getting is:
E_GSE_UNCONNECTED_CENTER_POINT -2147221218 A Line center point is undefined, it has no Connection line.
Has anyone come across this? Does anyone know a good work around?
TimHodson
Thanks for reporting this bug to tech support. It is recorded under NIM083531. This problem occurs when the curve is an exact half circle with a central angle of 180 degrees. Curves greater than 180 degrees are now supported at 10.1. See more info under the help topic Entering data into the parcel traverse grid.
As a workaround you can create these half-circle curves as 2 quarter-circles instead. It's easiset to do this using the traverse grid over-rides for tangency (using * in the bearing), and central angle (using 90d in the second curve parameter). See an example video in the attached zip file.
-Tim
