Has anybody experienced a problem trying to use Deed Drafter on a 32-bit machine? Has anybody successfully used DeedDrafter on a 32-bit machine? I've read all the Deed Drafter supporting documentation and it doesn't say anything about requiring a 64-bit environment. Our ArcGIS 10.2.2 installation works just fine on the same machines.
Basic configuration info:
32-bit WIN7Pro SP1 and ArcGIS 10.2.2 with patches (1022-DT-GFSS0-Patch, 1022-DT-PFGM-PatchB, 1022-DT-GD-Patch)
Out of 8 workstations have 2 with 32-bit WIN7Pro and get a System.Exception everytime the user tries Deed Drafter. The text body of the error message reads (See attached):
System.Exception: Error initializing ArcGISRuntime. Unable to load ArcGISRuntime
deployment ---> System.DllNotFoundException: Unable to load DLL
'RuntimeCoreNET.dll': The specified module could not be found. (Exception from
HRESULT:0x8007007E)
at ESRI.ArcGIS.Client.NativeRuntimeMethods.SetInstallPath(String path)
at ESRI.ArcGIS.Client.ArcGISRuntime.Initialize()
--- End of inner exception stack trace---
at DeedDrafter.App.Application_Startup(Object sender, StartupEventArgs e)
The RuntimeCoreNET.dll can be found in the DeedDrafter folder but it Windows will not register it saying it is a 64-bit .dll.
Any tips to get it it to work on a 32-bit machine?
Thanks
