Connecting pipes and manholes
2853
09-27-2013 06:30 AM
DenisCalarco
Okay, so I finally got the Xray to work on the LGIM.  We went out and started locating manholes with our GPS, which imported wuite nicely into the database.  Now I cannot figure out how to connect the manholes together.  Ive created pipes, connected them to the manholes, put the inverts and elevations in, to and from fields are filled out, but they dont seem to actually be connected.
Is there something I need to do different?  I cant assign flow directions or anything.
JoshuaDamron
If you are trying to place arrow symbols on your lines, this video will help you to learn more about how you build symbology: http://www.youtube.com/watch?v=WL81TflbGNI
If you are trying to create network connectivity then you want to learn more about geometric networks. Here is an introduction to how geometric networks function: http://video.esri.com/watch/2012/geometric-networks-an-introduction
Here is a good post titled "Geometric networks for water utilities" from the ESRI blog:  http://blogs.esri.com/esri/arcgis/2009/11/17/geometric-networks-for-water-utilities/
All the best!
