Avoiding gaps and slivers in the parcel fabric
4739
7
03-30-2011 10:55 AM
TiffanyPuett
Any ideas on how to manage this or what the best workflow for this would be?  I realize you can add the fabric to a topology, but it shouldn't be necessary.  I would like hear about what others are doing.
Thanks in advance!:D
NickKenczka
Hey Tiffany,
I'm curious, are you seeing gaps and slivers in your fabric?  The fabric inherently has some "built in" topology rules, so you really shouldn't need to run the fabric in a topology outside of the normal fabric environment....
TiffanyPuett
Here I'm creating a new parcel in a new plan.  I've included the details for line construction as well as the join details in case I'm missing something.  See the "First Glance"  sort of looks okay but I notice the 2 new line points.  I'm okay with the one to the southeast, but can't figure out why there's another one on the boundary here.  So I zoom in.  Notice the sliver in "Detailed Look."
The team at ESRI said they are currently looking at a fix for the next release where you can reshape some edges to match up with your new survey.  At 9.3 we used topology editing tools for this.
I started this post because no one seems to share my concern, so I'm just wondering how they manage to edit without said slivers & gaps!
ChrisBuscaglia
It looks like there are two points very close together, one was picked up as a line-point and for some reason the other wasn't.  Can you please turn on regular points and then send another screenshot of your "detailed view"?  Thanks
As a side note, there is a "topology" threshold for line-points.  By default, the line-cracking tolerance is set to 100cm.  This can be changed using a registry key, please also let me know if this gap is larger than 100cm.
Chris
TiffanyPuett
.....hmmmm as it turns out there are 2 line points there that are really close together--more like 10 cm.  This is something that I've seen hanging out since the original coverage conversion where little slivers created polys, that, once discovered, would be merged to the appropriate poly.  If someone forgets to merge the line segments afterwards then the extra line point will get left behind.
Is there a GP tool I could run to merge those that would not compromise my line-poly topo relationship?
TiffanyPuett
FYI, by logging an incident with tech support regarding the formation of an overlapping poly being created when using curves in the fabric, it is now a bug with using the parcel remainder:  NIM067973
While they're currently working on patch post SP2, perhaps this will be fixed then.
AhmadNammourah
Dear,
I'm searching for training material about Survey analyst extension including the training data.
please any one help me.
ChristineLeslie
