Symbols in schematic diagram not get proper
2418
05-22-2011 09:20 PM
VaibhavTelange
Hi sir,
I have occured symbols problem in schematic diagram. I am currently use 9.3.1 version software. I have used Geo-Angle directed and Geo-Partial overlapping links algorithm to generate schematic diagram on web. Symboles not comes on flow of direction.All symbols comes on same direction. I have attached screen shots of schematic diagram and algorithm please find it.
RickAnderson
Occasional Contributor III
Symbols are static in nature.  In Schematics, you can configure a rotation attribute that will rotate based on a database field.  You can also use the Geo-Rotate Nodes Along Links algorithm that will do this without being field driven.  Sometimes you need to change the initial orientation of the symbol itself from Top-Bottom to Left-Right so that it draws better after using the algorithm.  This happens with switch symbols in many cases.
