Lock the number of records on table.
5729
05-18-2016 04:32 AM
IgnatiusRumambi
Dear all,
I had downloaded a file (including table) from the ArcGIS Online, I opened the table in the arcgis online and I saw  that the totaly number of records more than 8000 .
Then I opened the file in my ArcMap and i could see that there were complete number of points. But on table,  I see no more than 1000 records (max).
How can I access the encrypted number of records in the table so I can see the real number of  records (like in the arcgis online, that more than 8,000 records)?.
thanks and Regards,
Ignatius
FC_Basson
This kind of limitation is normally set by a Map Service.  What kind of file did you download? Shapefile? Feature Service layer file?
FC_Basson
IgnatiusRumambi
Hi Basson,
You're right, this file was set by the map service, below is the link to this file, that's the reason that i can't even save on my local drive.
http://services.arcgis.com/Fq8RfjNOmWcJAoEJ/arcgis/rest/services/ICTandIndustry/FeatureServer
thanks for your response,
Ignatius
FC_Basson
As you can see in the service description the Max Record Count is set to 1000.
DanPatterson_Retired
Ignatius, could your mark FC's answer correct so that there is some closure on this thread.
FC_Basson
