how to change the distance of the semivariogram on the geostatistical wizard
1578
04-05-2019 01:52 AM
NdamuleloMusumuvhi
hello hi, i am new , a student in learning arcgis , but i have been trying to do some interpolation using the Geo statistical wizard (kriging), but on the semi variogram graph, the distance is showing in distance not in meters I tried changing the display units on the layers properties but still am not prospering, i even tried to change the local projections of the layer but still the problem perpetuate
DanPatterson_Retired
Did you use the Project tool to make a new copy of the file which is in projected coordinates?
Project—Data Management toolbox | ArcGIS Desktop
Define projection won't do it if that is what you used
NdamuleloMusumuvhi
@dan patterson ...i didn't..... but i after i did use it , it worked just fine thanks alot
Good.  Please mark the answer correct so others know one was found.
