hot spot analysis of 911 calls on map center
3399
02-17-2011 06:33 AM
CarrieKeneally
hi,
Is there a tutorial for the hot spot analysis of 911 calls map that is on the map center page?
I am using 9.2 and I am not sure how to get started with this.
Carrie
LaurenRosenshein
Hi Carrie,
Glad to hear that you're interested in learning more about Hot Spot Analysis!  My suggestion would be to use the Hot Spot Analysis Tutorial.  Even though the tutorial is designed for 9.3/9.3.1 is should still provide you some valuable step-by-step instructions for 9.2.
You may also find the videos and other resources at our Spatial Statistics Resources Page helpful!  You can also get to the page from the easy-to-remember URL: http://esriurl.com/spatialstats.  From there we have links to lots of instructional videos, free training seminars, and a ton of other stuff.  I would definitely suggest starting with the 3 short videos on Hot Spot analysis.
Actually, we just did a Live Training Seminar which was an Introduction to Spatial Pattern Analysis, and that probably has a lot of useful information as well.  It is all done in 10.0, but all of those tools (and the associated workflows) are still relevant for 9.2.
Hope this helps!
Lauren Rosenshein
Geoprocessing Product Engineer
