Cluster and Outlier Analysis (Anselin Local Moran's I)
1170
04-03-2018 11:00 AM
NikosTziokas
Hello everyone,
I am currently working on a project which I must calculate Anselin Local Moran's I. I am using polygon features and ArcMap 10.4.1.
Here is my problem: when I am trying to run the command ArcMap shows no problem running the command but the output feature is never created. I have double checked the Path of the output feature!
Any thoughts of what might goes wrong?
Sorry for my english. Thanks in advance!
DanPatterson_Retired
Do you mean running the tool from within ArcMap? or via script?
You might need to show your paths for the inputs and outputs... maybe output was created but it just wasn't added
NikosTziokas
Thank you for your answer.
I am running the tool within ArcMap.
I fixed it! I just re-opened the program and re-run the tool. The output feature was created after that.
