Calculating Correlation between 2 (or more) Rasters?
5986
06-01-2017 05:44 AM
SimonJackson
With Vector data I can understand correlations between layers using regression tools such as OLS.
What tools would be suitable to understand the correlation/relationship between two (or more) different rasters?
I saw Band Collection Stats but I think this just outputs a table.  Was hoping to have an accompanying spatial output as well.
Any pointers would be great.
DanPatterson_Retired
Yes do read that discussion on 'correlation' and 'regression'.  It is generally a term badly used.  Simple visuals showing co-location can be accomplished using a variety of tools.  If you have nominal or ordinal data, you won't be using regression at all and if you want to go with non-parametric tests of statistics there are few built in.  the Combine tool in SA will at least allow you to determine whether certain pairings/groupings of attributes occur.
I might be best to describe the nature of your data before useful recommendations can be made.
SimonJackson
Thanks Dan - the combine tool and your comments in the other post are very helpful.
I will mark it 'Assumed Answered ' then
